Cloudflare SSL Not Working On Cloudflare
Cloudflare Flexible SSL is not working on InfinityFree. I tried another hosting and it work
How can i fix?
That hosting was GitHub Pages
Did you install SSL in control panel?
Why not? What do you see?
Last time I checked, it was working fine. But some scripts don’t handle it properly, so it’s usually better to install a self signed certificate on your account and switch to Full mode.
I have a last question. According to the guide of how to use cloudflare on IF. There is possible to don’t use www but only @?
You can use only @, but if someone visits the www version of your website, it will not work
Ok, i want to use IF with @ to redirect to www where is pointed to another web hosting. Is it possible?
Yes, possible. You are a superb experimenter though :sweat_smile:
I would personally just use Cloudflare Page Rules if all you need is a web redirect.
