epiz_30431036
I had Created Subdomain In Cloud Fare
But It is not sowing in Subdomains Or FTP
How to access The Subdomains Added in Cloudfare DNS
Plesae Say
epiz_30431036
Plesae Say
Hello @SimhaVedantam,
What you wrote is confusing. So please answer the following:
Create subdomain in control panel also and point hosting IP to Cloudflare for that subdomain!
I think you added A record pointing to server IP as per client area?
How To do that Can You Please Say?
Yes I have Created Subdomain named Same in C Panel of Infinity Free Also
How’d you create subdomain in CF? You mean you added the A record? Also please share the domain you are referring to.
Yes I have Added Through A Only
My Domian is Simhavedantam.in
What subdomain url?
No I have Not Installed Should I ?
Yes you must. Also what ssl config is there for you in CF?
I don’t Know that…
Because I’m Using Normal ZeroSSL Certificate for the SSL Certificates
What is set in Cloudflare SSL settings? Is it flexible or full? make sure it is flexible. Create ssl for your subdomain. and install it.
You should install SSL for subdomain also!!
Keep this in mind!
Ya Thank You @jaikrishna.t and @HELPINDIA
Issue Sorted
I have to use HTTP Protocol
i.e, http://test.simhavedantam.in
I Understood Now
Thank You, Guys… For helping me to understand
OK but not secure at all.
