When ssl/tls for private key and take csr i then i take the Certificate and when im trying to upload it its say its not for my domain samothrakisnews.gr can you help me?
There are a few different reasons why you might see that error, all of them are described in this article: https://infinityfree.net/support/the-uploaded-certificate-is-not-for-the-domain-name/
If that doesn’t answer your question, could you please share the certificate text (not the private key!) here? That way, I can check it and see if there is any reason why it wouldn’t be accepted.
i think i made it to fix it now http://samothrakisnews.gr check it please if you can just to be sure…
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
I checked the contents of the certificate, and the certificate seems OK.
However, the SSL certificate was created for www.samothrakisnews.gr, instead of samothrakisnews.gr. The certificate also contains samothrakisnews.gr as an additional domain, but our SSL wizard doesn’t check the additional domains section of the certificate.
So I admit that this is a bug in our panel, but until that’s fixed, it means this certificate cannot be used.
you can fix that problem?
Not easily, no. I can’t change the contents of the SSL certificate, and I can’t make changes to the control panel just like that. I can submit a bug report, but I don’t know when it will be fixed.
