Can't connect using FTP!
I have seen a knowledge base article but it did not help but or some reason when i try to connect it says certificate invalid! Im using filezilla and am not sure why this is happening. I have double checked my details and they are correct!
Thanks
also am i allowed to use this site or is it not allowed?
Thanks
https://ibb.co/kouOoS
That error is not caused by your configuration, but rather by an “issue” on our end. Our FTP server has a self signed certificate, meaning it’s not accepted by other systems. However, I can assure you that this is completely intentional and you can safely click OK and proceed with the FTP connection.
https://www.sslforfree.com/
You’re allowed to use whatever SSL provider you want, but that doesn’t mean you’ll be able to: https://infinityfree.net/support/cannot-use-or-have-problems-using-lets-encrypt-or-sslforfreecom/
Ok thanks but i just tried again and it did not work the FTP and im unsure why! The password is 100% the same as my account password so im unsure why it is not working!
Thanks
Thanks
So what do you see? Do you get any error message?
@phpscriptsdemo
can you try to use it without SSL FTP (TLS)
and then check whether is connected or not
how to https://forum.infinityfree.com/discussion/comment/11102
