The websites do not load at all from my Vodafone cable internet connection.
Test-NetConnection 185.27.134.65 -Port 443 returns:
TcpTestSucceeded : False
curl.exe -Iv --connect-timeout 10 https://busphoto-bgn.xo.je/
returns:
- Host busphoto-bgn.xo.je:443 was resolved.
- IPv4: 185.27.134.65
- Trying 185.27.134.65:443…
- Connection timed out after approximately 10 seconds
curl: (28) Connection timed out
Hello,
I am having a connectivity issue with two InfinityFree websites:
https://www.rogis-fahrinfo.xo.je/
Both websites work normally for other people and they also work for me when I connect through my phone’s mobile hotspot.
However, they do not load through my normal Vodafone cable internet connection.
My public IPv4 address on the affected connection is:
91.65.161.204
Both websites resolve correctly to:
185.27.134.65
I tested DNS using both my normal DNS server and Cloudflare 1.1.1.1, and both return the same IP address.
TCP port 443 does not connect from my Vodafone cable connection:
The HTTPS connection also times out with curl before any TLS or HTTP connection can be established.
Traceroute from the affected connection reaches:
wildcard-uk.edge3.manchesteruk2.level3.net [195.50.121.134]
and then stops responding.
When I use my phone’s mobile hotspot on the same PC, both websites load normally.
So the same computer and browsers work with a different internet connection.
Could you please check whether my public IP address 91.65.161.204, or the Vodafone IP range it belongs to, is blocked or filtered by InfinityFree, Wildcard UK, or any firewall/DDoS protection system?
Thank you.
