Can you fix this? I need help
My website URL is:
http://justsurvivemc.com/
What I’m seeing is:
A Cloudflare error.
I’m using this software:
NameLessMC CMS
Additional information:
See here:
https://community.cloudflare.com/t/i-keep-getting-error-1016-after-connecting-infinityfree-to-this/161744/1
Does this article help you?
https://infinityfree.net/support/cloudflare-shows-error-1016-origin-dns-error/
Thanks!
I can’t change DNS because it says it’s hosted by Bytehost
Update:
I’ve created a new Cloudflare account and connected my domain. How can I use infinityfree host in cloudflare?
The easiest way to do so is to disable our Cloudflare integration, wait for 24 hours, and then add the domain to Cloudflare and let Cloudflare scan your records.
You can also add the records for your root domain, the www subdomain and any other subdomains yourself by creating CNAME records pointing to your account’s main domain. That process is explained in more detail here:
https://infinityfree.net/support/find-your-ip/
Thanks, I got it figured out.
