Can not use cgi-node
I can not use cgi-node module. Installed it and placed the files. Still can’t.
http://cgi-node.epizy.com/index.jss
It is supposed to say “Welcome to cgi-nodeaaa” but it is just outputting “aaa”
CGI-Node provides the ability to run JavaScript on
any web server just like PHP as a CGI using Node.js.
It only supports php not node.js, So you cannot use it on free hosting!
Free hosting does not come with a cgi-bin system to run custom CGI applications. So I’m sorry to say you cannot use this workaround to run Javascript code on our hosting.
CGI applications can only be hosted on premium hosting. But then you could also just use the Node.js module to run your Javascript application the way you’re supposed to.
