Can i replace my domain and keep the same website?
Hello, recently i noticed that Freenom is a scam, so i opted to buy a .com domain, so, my question is: In Infinityfree can i replace my .ga domain to my new .com domain? And, how can i replace it?
Thank you :slight_smile:
You can add the domain in the vPanel. If you use wordpress, change the installtion domain via Softaculous or edit the wp-config.php.
There are many users who use these free domains, it works, but is not good if you want to get ranked on Google etc. There are some problems in the freenom system that causes domains to disappear.
Thank you bro.
Check Freenom in Trustpilot bro.
The easiest way to do so is to add the new domain as a Parked Domain to your hosting account, and park it on top of your existing .cf domain.
After that, your site may either just work or you may need to update some things to make it work with the new URL. How exactly that works depends on the software you’re using.
