Can anyone please help me I've made a mistake here and I don't know how to solve it
What is the issue? We can’t help you if all you do is say “I’ve made a mistake” and provide a picture.
I can’t access my website , because it wants password that I’ve forgotten
Don’t mark a response as the solution unless it actually solved your problem.
This looks like it was created in the directory privacy feature in the control panel. You should be able to remove it from there
I’ve checked directory privacy , several times I didn’t try to protect any Dir , actually yesterday I was drunk and I don’t know what I’ve done :sob:
Can you screenshot the interior of the htdocs folder?
Remove it and try?
You are probably going to have the edit the htaccess file as well, but remove the files that @KangJL suggested first.
Thank you guys everything is fine :handshake:
