Caching issue on MyBB Forum
Account Name: epiz_28291045
The issue is that the php pages appear to be being cached on the server-side, it is very similar to an issue described here regarding MyBB forum software (which I have installed on this account). Which appears to be related to micro-caching
Well, you can add below statement to .htaccess to enforce no caching.
Cache-Control: no-cache, no-store, must-revalidate
Pragma: no-cache
Expires: 0
Hi, thanks for your prompt reply, however, unfortunately this did not resolve the issue
We don’t do any micro caching on the server. We do send caching headers to browsers so most static files are cached. If you’re using Cloudflare, they cache some things too. Some network administrators also cache pages on the network level through a proxy of some kind.
Do you have any way we can verify this caching? Can you give us a page where we can do something and see the caching in effect?
I’ve set up another forum site on a free subdomain which doesn’t seem to be affected. So I’ll check if this problem has something to do with the domain/ssl/other protections.
Sorry about that, probably should’ve done that first.
Thank you for your help.
