Building API Is Possible?
I was trying to build a really simple API for my website, however anytime I try to access it requires JavaScript. Is there any way to disable this requirement for the API?
No, it’s not possible to disable the browser validation checks on free hosting, which means you cannot host your API here. You need to upgrade your account if you want to host an API application.
Does this restriction also impact the ability for robots like the Google search bot to access the website (and thus the website will never show up on Google) or is there special exceptions in place for common search bots?
Search engine crawlers do run Javascript and can accept cookies, so they can access your website.
