Bg Images not showing
Background images anit workin, really need help.
ive tried caps and file location.
ill give everything
minecooking.kesug.com
images:
Untitled design (1)
(Yes i know it weird to use a phone)
Try using a different filename, something is redirecting that image to something else:
Still isnt working
Working fine for me:
Although it looks really bad if your screen size is anything other then the size of that image (Using images for variable-width backgrounds is a really bad idea)
Try clearing your cache
Thanks so much and ill change that
