My Flutter app needs to call the SEAIT DTR API directly. Requests to https://seaitdtr.page.gd/api/v1/\\* are receiving an HTML JavaScript/cookie verification challenge instead of JSON. Can direct mobile/API requests be allowed for these routes, especially POST /api/v1/auth/login? If this isn’t supported on my hosting plan, what hosting setup do you recommend for a PHP/MySQL API?
No, that isn’t supported on free hosting. The HTML page you’re getting is InfinityFree’s browser security check. It can’t be turned off for one route like /api/v1/auth/login, for a file type, or for a user agent.
The check requires JavaScript and cookies. A Flutter app making direct HTTP calls can’t run it, so it gets the HTML page (the one that loads /aes.js and sets a __test cookie) instead of your JSON. The request is stopped before it reaches your PHP code. The article lists mobile apps and REST APIs as things that won’t work on free hosting:
The article says the way around this is premium hosting. It protects sites with less restrictive methods, so mobile apps and APIs work normally. It doesn’t recommend any other specific setup, so I can’t tell you which one to pick for a PHP/MySQL API.
