Animes.ga is already assigned and in use.2
animes.ga
I’m having this apparent problem, when I try to insert my domain, the following error message appears.
“Is already assigned and in use.2”
but, I do not have access to the account, it is not mine , but the domain is;
domain:animes.gg
it means it is already on an ifastnet powered host
support.ifastnet.com is support link, contact them or get new domain name
I guess you have missed this text when deactivating your first account:
If you want to use these domains on another account, you have to remove the domains from this account (through the Control Panel) BEFORE deactivating the account.
If you ignore that message and deactivate the account, then yes, the domain is already “in use”. It’s in use on your other account, which you deactivated without removing the domains.
I solved it already , tanks
