Allow_url_fopen is not enabled
Username (epiz_26797659) or http://ituschool.epizy.com
I don’t find any things to solve this error. Please help me.
You bought the script?
No. I downloaded it.
The script costs $59
You have downloaded a nulled script,which violates IF’s T0S.
And nulled scripts have malware in them(bad for you,visitors,servers)
Now remove it to save your account.
Please, I need to just test it to see it is good or bad. Than I can brought it.
Please help me.
You want to ruin the servers?
no
These nulled scripts will ruin the servers.
Now delete the script
ok
If you try to cheat IF,Admin will have to suspend your account.
[Admin may check your account…]
ok
It is enabled:
And if you want to test pirated software, do it somewhere else. We don’t tolerate it on our servers.
