Akeeba is not working
https://jozefjurica.epizy.com/
Akeeba Backup - An unhandled Exception has been detected
500 realpath(): Argument #1 ($path) must not contain any null bytes
File <root>/administrator/components/com_akeebabackup/engine/Util/ConfigurationCheck.php Line 295(please share the FULL error message you see, if applicable)
Akeeba Backup doesn´t work. It was OK, but after updating PHP the message mentioned above is shown. Is any idea to fix it?(other information and details relevant to your question)
Hello
We highly discourage the use of backup plugins here as it’s easy for them to corrupt the backup, and they create a bunch of load on the server that is known to lead to suspensions.
Thanks for recommendation. I uninstalled Akeeba Backup. Best regards.
