Add SSL Auto Renew
How can I create an auto-renewal of the SSL certificate of my website in InfinityFree?
I believe this is only available on premium hosting
Best way to get lifetime SSL is to connect the domain to Cloudflare. Please refer to this article. Hope this helps!
I don’t think works with a free subdoamin :-1:
Ok
Hi @OverloadedTech,
Yes that’s true. It only works with ccTLD’s (.ml, .tk etc.) or TLD’s (.com, .in etc.)
Ok, end
You may also try Free SSL at InfinityFree, SSL for Free.
Hello @anon64434604, as the question was about auto-renewing SSL, the IF SSL is not an option.
Thanks.
