A trusted SSL Certificate was not found
I had an issue when I wanted to install WordPress using Softaculous where I couldn’t use SSL even though I had already gotten an SSL certificate and had configured it in CPanel automatically.
Your site’s SSL certificate works fine; you can ignore this warning. Softaculous is just unable to detect it, but that will not cause any issues, so you can proceed with the installation as you would do normally.
I see a WordPress site has been installed just fine on your website:
hi, thank you for helping. yeah i just try and ignore the message. thankyou bro
