A simply annoying issue when writing HTML and CSS
https://ilta.ga OR http://www.djtpa.ga (both sites hosted with InfinityFree)
This is a HTML/CSS Web Design Issue I have, which can be seen on BOTH sites.
Issue I have
When designing a <div> element, I try to write it to fill the WHOLE width of the page, but there is a small 10px(ish) border between the edge of the page. I personally think this is specific to InfinityFree because there are no other recourses online covering this issue; which would imply that it doesn’t happen elsewhere. How can I fix this?
This issue can be found at the bottom of https://ilta.ga and the top of http://www.djtpa.ga
CSS and HTML are being rendered on browser, so it cannot be related to the hosting.
they use html,body{padding:0;}, you can also use it in your css file so it’ll fix the 10px border.
Is the body margin set to 0?
body {margin:0}
Thanks mate
