500 Error enable display_errors
(https://bldcommunity.xyz/)
500 Error, please check your php script / enable display_errors in your cpanel
i already enable it but still get same error
Hi and welcome to the forum! That error is generated server-side, so you need to check your .htaccess file for any faulty line and remove those to fix it.
i will try
ye thanks it work
500 server error probably cause off php script contains error .
I’ve got a weird problem ,cause if the DirectoryIndex set in htaccess ,it says 404 not found .
so I set the redirect to http://swp153.fnhost.org/
Forum scripts like Invision not recommend in free hosting
