no
just http to https redirect by a plugin
Can you disable that plugin?
Just go to filemanager and rename that plugin will do
I try to delete it
I deleted it, but nothing good happened
The same issue here for a couple of hours.
WP installation (via Softaculous) on vol17_1 redirecting to 500 Internal Server Error or 403 sometimes. no change in the .htacess code.
What should I do now?
damn, what should i do
I had nothing to do with the website. I checked the site 6 hours ago and everything was fine, but two hours ago when I opened the site again, I encountered error 500.
Isn’t it strange?
I kind of suspect it’s not your issue now. I saw three(including this) topics about the same problem. and my old website(which I don’t really use it anymore) that I haven’t touched for 2 months has 500 Error too. Sometimes even Timing out.
about errors:
I assume you are using the nulled version
because as far as I can see here the latest version asks for an active license
or the old version doesn’t work on PHP 7.
It is also possible that you have been hacked
s**t
