404 error on top domain, sub domains working fine
As the title says, getting a 404 error on my top domain but on sub domains everything’s working fine…
swooty.uk - 404
dev.swooty.uk - fine
swooty.rf.gd - fine
Exact same files in each directory also.
www.swooty.uk works, going to try checking my records.
Just put a redirect on swooty.uk to www.swooty.uk for now, let me know if you find anything - if not no worries, fine to use this work around :slight_smile:
EDIT: maybe not, redirect loop :lol:
swooty.uk seems to be working fine here, so I suspect this is just a DNS cache issue. When did you change your nameservers to Cloudflare? If that’s less than 48 hours, that might explain the issue.
Was happening before swapping to Cloudflare, I’ll try again tomorrow to see if swapping has fixed it.
Thanks
You need to correct your DNS addresses, before you may see the instructions for the second “CNAME”.
