Partly due to xfce4, a light DE
Still wait
I was getting confused as it looks like openbox
And have a xfce4-terminal running on it
(Look at my edits and find this reply a bit more logical)
VirtualBox version seems dated
i only use openbox :v
it’s actually VirtualBox 5.2 ._.
Dated, yes
Consider these vm softwares:
VirtualBox 6.0 is the last version that supports Windows 7 as host although it might not make much change in ui
VMware Workstation Pro 11 is the last version that supports Windows 7, looks a little nicer that VirtualBox
VMware Workstation Player 7 should also support Windows 7, and it’s free
I also noticed that the Knowledge Base links if I were to copy-paste them now have embeds on this forum! For example this:
now shows up correctly and I don’t have to change the link to /t/{TOPIC_ID} for it to work, even though I used it until now!
I also noticed the new Softaculous button next to the File Manager’s button in the Client Area when you click on your hosting account, which is also a twist compared to the method of going into the Control Panel first to log into it, and the new function of adding a domain directly through the Client Area itself for a hosting account you have, which is still faulty because it doesn’t automatically create the document root… I could also create a new database from the “MySQL Databases” section of the Client Area and also manage it all - except some other things like DNS records and other things that for now are in the Control Panel itself - through one place!
Does InfinityFree use https://www.vultr.com/?
:person_shrugging:
Anyway, I’m still very happy of the new Client Area changes.
Follow-up just to say this:
Hi and welcome to the forum, @JoniDeev! Good to see you helping the guy that wasn’t being more specific in his queries!
be sure to zoom
we will have to edit the IF tools so that the BG color corresponds to the CA (for now the shade is different - almost imperceptible)
I don’t like that it says “Parked domain” here under yellow
I quote; it confuses the end user even more when they add the domain into an account without aliasing.
You didn’t notice the toolbar items in the screenshot? :innocent:
I did, but kept it for last. Time to make the change!
Follow-up! Here it is:
OxyDac-if-tools (1).html (11.5 KB)
Now with the new Client Area white theme shade!
Copied from meta - maybe it will be useful for someone, although our forum differs in some details
Trust Level Permissions
“R***y by *mail”
The couch surfing dog!
There is no need to create a new separate topic for all the memes you post. Post them here instead, as this is better! Anyway… :rofl:
https://twitter.com/nixcraft/status/1686092141830066176?s=20
direct link, in case you don’t want to go thru twitter
