So today I learned an important lesson.
Make sure your speakers are on before messing with all the cables behind your desk because you think something broke or went bad.
It’s JetBackup anyways
No, after downloading the backup from Mar 23 and Mar 22, I could see that the Matomo Analytics plugin is taking a lot of space, but the inodes is no where to find, and it only contributed 100 MB (So the remaining 150 MB remains unclear.).
There’re public uploads, but they only contributed 0 KB, due to a simple fact that my site wasn’t well known (and might never will
While today it becomes 700 MB (What the f*ck?). I think I should quickly react to this so it doesn’t eventually eat all my disk quota ![]()
Messing around with Cloudflare and just enabled HSTS for my site. Everything seems to be fine now ![]()
HSTS and Cloudflare shouldn’t have direct relevance to inode usage, IMO.
While not sure what is the intended function for public uploads, Matomo alone would generate temporary files whenever there’s a hit, and a backup might be in place to capture those as well (if not excluded) and hence the increased inode usage. (I believe)
Try generating a inode count list and see which subfolder has the most file count and work from there.
I never say they had relations lol, these are separate things ![]()
It’s on my to-do list, but seeing how I’m relatively far from the limit, it’s OK right now.
2 months later and I finally started to refine my WordPress theme (Which is left buggy on my own site) ![]()
Enjoy your time ![]()
I think I just mostly completed my WordPress theme
, now it only needs more refinement + dark mode support + actual customizing options (Yeah if I need to change something I would just go back to the codebase and change stuffs
I do get a issue where the navigation menu closes itself on mobile sometimes. Unable to properly replicate the issue, guess I have more to do lol.
Don’t ask me for a GitHub repo now, I was locked out of my GitHub account due to the fact that I cannot do 2FA these days. And I don’t remember where’s the recovery codes. But you can see it in my website ![]()
By the way this is just the first step of my plan, a plan that’s so big and I highly doubt whether I can actually carry it out or not ![]()
Send us pictures of some toilets ! ![]()
Heres a track I detuned a while back, enjoy ![]()
at least its not a crazy french keyboard ![]()
They basically directed you to the same link from the article listed in my post ![]()
OK, so in short you put your Logflare api key in the provided place in the code
and then you create a worker on CF
and you put that code in there and that should be it
CF worker has 100,000 hits - so it is quite enough if the domain is hosted here.
In the sense that the site will be suspended sooner than you will reach the CF limit
We have several letters that do not exist in Eng, so it’s useful to have a local keyboard…
The only thing that irritates me is when in the BIOS or during the installation of Win (when there are no language settings yet for the keyboard) then when a prompt appears
and asks YES or NO (press Y or N) when I press Y then I get Z
so I have to remember that actually for YES I need to press Z
sounds like drunk or high lol
I understand that there are things on the french keyboard that are not available on a uk keyboard
but what I dont understand is why some idiot that designed the french keyboard thought it was necessary to press shift to get numbers and the default without shift is symbols ??? surely numbers are more important !
You are right numbers are more important
Speaking of numbers
I find it even sillier how the French pronounce some numbers
instead of having a separate word for 70 (and some other numbers)
they pronounce 60 plus a certain number and even crazier combinations
I see , the bulgarian numbers pronounce is better and easy😅
My brother some years ago started to learn French because of his work… but he gave up at the end😅
