Thanks for reminding me that I still have that dumb Elementor on.
Basically there’s only 1 page which is on elementor and I just forget every other day that I should rewrite that page in plain html ![]()
Also had the same issue for the past few days…
After some digging it’s more like HTTP request that involve database data that shows a 5s latency, other static ones are just fine. (Database overloaded?)
If it’s a server-side issue then probably everyone here will face such latency.
Unless there’s some load-balancing stuff so different requests were sent to different servers, and there’s one of them suffering from issues.
this was an interesting read
http://www.bitsavers.org/pdf/univOfIllinoisUrbana/ordvac/ORDVAC_Manual_Volume_1_1952.pdf
That’s why I’m asking, and so far KangJL mentioned that he has the same issue for days as well, and we are in completely different locations.
his problem was different → he saw more colors and circles
Have you maybe eaten some mushrooms in the last few days ??
ain’t mario here, no mushrooms ![]()
how bou’t you @KangJL ?
I wish I had some mushrooms ![]()
Welcome back @Meishin!
Why do you all have to be across the world from me? I went to sleep and woke up with 37 new replies in here. I feel left out!
Shitake, anyone?
It seems that the forum has still not decided how many those months were ![]()
Welcome back!
New version
- added approximately 10 new contents eg
no IP = Bodis(1* a lot of text) - blink animation on the copy button (confirms that you have copied - green)
- style has been changed
- fix for Edge/chromium - buttons borders and others
OxyDac-if-tools.html (16.6 KB)
(1*) example
It seems like something went wrong on our end that caused your domain to not be set up correctly in our nameservers
(the server did not assign an IP for your domain, but it still leads to Bodis parked service).
This is a known issue in account creation.
To fix this, you will need to remove the domain from your account and add it again. That will cause the correct DNS records to be configured.
Please try to understand that it can take up to 72 hours for domains to become visible, because any time you remove or re-add the domain, you’re essentially resetting the timers.
Note: If you had an SSL certificate installed you will need to reinstall it.
No need to get a new one, just find the existing certificate and hit the automatic installation button again.
In certain cases - after recreating the domain name,
the directory your domain name is linked to will change from htdocs to nameOfYourDomain/htdocs,
so you’ll need to move your website files from the old directory to the new one.
end of example
Relatable for sites hosted here :))
Going though old files and found these 3D logo mockup I must have made awhile back to. Should I change the TH logo to one of these?
What is your favorite?
(I tried to put them in order of date)
- (Current)
- 1
- 2
- 3
- 4
- 5 (Current)
I don’t think you will be able to find a place to use it,
because here I reduced it and when it is reduced (small size) it doesn’t look like it is 3D at all…( if it was white - it would be even worse).
censored
to the right of the existing one
only when I added these two is it a bit more visible
maybe to simply paint the existing logo in blue to be in harmony with the other blue elements, although there is no need
maybe make it fairly transparent and monochromatic (original large one)
so then you can use it as a background under some text and the like
btw. in one picture the password is visible
