27 !
Great news, this has been a long time request and I’m glad to see it materialize!
Ouch… :sob:
And I’m not even an active MOFH reseller :joy:
Your biggest problem is because you call font awesome (huge package)
and you only use 3 icons
so I removed it - and added 3 SVG icons (if you need more, find them here https://icons.getbootstrap.com/)
  • declared charset
  • declared the language
  • added CSS
  • aria, alt, titles - to icons and links
  • rounded corners for img so it’s not square
  • hover over the SVG icons, the color changes to yellow (fill), and you can change it to something else to match the color of the background
  • changed color for | (separator) down at the bottom where the links are
  • spaced the elements more apart - so that there is more room when someone wants to tap the icons with their finger ( I defined the distance between the icons in CSS svg.bi {width:4.3em} if you need more then edit it)
  • SVG icons - size is defined under <svg> + width="40" height="40" (if you want bigger - edit it
  • optimized the image (orchid.jpg) - so upload it instead of the existing one (it’s at the end of my post)
I didn’t touch Google fonts…
Download index.htm (4.5 KB)
Use this img (btw. rename the extension from jpeg to jpg)
Now I’m trying CNAME verification on my domain’s side as well… As always there’s time to wait for DNS to propagate!
Follow-up! After some time I managed to add it to one of my existing hosting accounts! Then I added some records to point it through DNS to that hosting account.
I like the new Inspect look on Microsoft Edge.
It kind of looks like Firefox’s.
One, i’m not skilled in programming
Two, it’s my site, not yours
Three, I don’t care
Woah… I don’t think Oxy meant any harm! He was just trying to help :hugs:.
Hi KangJL,
Do you know if this is an existing feature or something that’s about to work? I have tried this but still no luck…
Cheers!
It worked for me. I was able to add domain via CNAME
Any error?
Should have said it yesterday but…
I made the big mistake of getting Minecraft
now my days shall be wasted for a while
Honestly though, maybe the wanting to do some programming and the enthusiasm will come back.
It’s been a combination of doing nothing, games and programming/music.
If I let off on myself a little bit, maybe I’ll get my vigor back.
You do realize you could easily ignore if you don’t care right? Why be an ass?
Hi KangJL,
I tried again after lunch and turns out it’s related to Cloudflare proxy. It’s working now. :+1:
Cheers!
Hi KangJL,
Just a quick question that pops into my mind, does the CNAME record have to persist after adding the domain to the account? Or I can just remove it now that it’s in?
Thank & Cheers!
I believe once domain is added to hosting account, CNAME can be safely deleted
Nice :+1:
Why you calling me names?
You don’t have to be a programmer to declare charsets in HTML and other things
If you don’t care why did you go to test your website on pagespeed at all?
why this post at all?
I thought that since you stated that you were lazy (and now you recently stated that you are not a programmer) that it was a sign that you were looking for help
and I simply took 20 minutes to help you
and maybe you learn something from it
If you don’t care, then at least work on your manners
and learn to write a simple ā€œthank youā€
even if you hate that other person or his actions.
You always have a choice whether to spread good or like a cuttlefish to release black int.
One of the values of people is what they leave behind as they walk through the world…
The choice is yours whether you will leave the desert or the green pastures behind your moves.
Because i like to follow trend and I’m stupid and never gained happiness ever?
