I know But My Real situation sucks.
same.
Iâm 2323rd!
1 month for me before I watched a yt vid
hey, I have only been coding for 6 months
oOf
I didnât need to use classes, so that might be why.
Well wellâŚ
When was the first time you got into coding for first?
I used to program in game makee language when I was like 10 (almost 8 years ago) but then abandoned for 6 years because of my real life.
august 2021
September of 2020âŚ
Technically, August of 2020 because of a camp, but September was the first time I tried it out of prompt.
nice!
@anon19508339 when did u start coding (i did in aug 2020 and my first major project was deployed (on if) in september 2020)
Yes!
I did it!
https://phantomforcestools.ml/exp.html
There, itâs updated and much better now.
It calculates how much exp you need to get up to a rank, and even displays the results formatted based off of your number system (adds commas every thousand, adds periods for decimals, e.t.c. What I said also depends on where you live, like if you live in Sweden it will be switched. Periods for thousands, commas for decimals, e.t.c)!
The game is called Phantom Forces.
Mobile support is going to be a major update, too.
Like it?
hA!
I made my script 10x more efficient and comfortable.
https://phantomforcestools.ml/main.js
Heck yeh!
Now I donât have to worry about the names of the files I need to load in because if I change the fileâs name itâs as easy as changing the resource name in main.js
Much easier than copy-pasting across every webpage
Itâs only working in exp.html rnâŚ
A bit of bad graphic design (the results text has same color with the background, which makes it invisible unless you highlight it)
But youâve done an interesting thing with commas!
Huh, itâs invisible?
Weird, it isnât for me. It should be gray, which is against a black background meaning it should be visible.
Weird, it shouldnât do thatâŚ
Why isnât it styling the outputâŚ
Can you tell me what browser version you are using and the browserâs name?
It works fine for me, see?
Google Chrome latest version.
Huh, IDK then.
Try refreshing your cache, because it should work.
Yep it works, how did it cache when i never visited your site before?
Havenât played but based on my gaming interests, it sounds cool.
The cache might have been corrupted, OR I was fixing/improving on it while you joined.
