I’m using LMMS
Time to quit.
Just spent 10 minutes trying to find the error on line 194
$sqlQuery_pastScreenData = "SELECT * FROM `lalalala` WHERE `var`=?, `var2`=?";
And
ed when I did.
Then on line 201:
$sqlQuery_screenData = "INSERT INTO `lalala` SET (`var`, `var2`, `var3`, `var4`) VALUES (?,?,?,?)";
Can you find them?
I eventually did
EDIT:
I’m also very good at writing error messages!
" IMPORTANT NOTICE: Because of technical issues the Freenom application for new registrations is temporarily out-of-order.
Please accept our apologies for the inconvenience. We are working on a solution and hope to resume operations shortly.
Thank you for your understanding."
Freenom is under matience.
Yep, and it happened just at the time when a friend needed a domain…
Neither do lemons (They are genetically modified from some other thing that I forgot the name of). Which makes the phrase When life gives you lemons makes no sense.
Anyone have recommendation for making a duplication of a hard drive?
My scenario: I have an old laptop with a spinning disk (in 2 partitions), just bought a new SSD, and I would like to make a exact duplicate of the disk. I’ve heard of some program or whatever, but I don’t remember what it was called.
This?
Software would probably be the easiest approach, but you could buy an adapter for both drives, and then just use an outer computer to make the copy.
I think that even SSD manufacturers offer clone tools on their websites.
I use paragraph 5 from the KangJL article (paragon) free version
If there is an OS inside…so one of the disks is a boot partition
sometimes they are hidden so they are not visible via OS
so keep in mind that it’s probably not just 2 partitions…
it depends on how old the OS is there… I think that win7 already has several partitions (recovery, boot, sys, etc.).
You can remove accounts using the MOFH api: “https://panel.myownfreehost.net/json-api/removeacct.php”
This is the first time I’ve even heard about the license plate themselves. Who thought that was a good idea in the first place?
Welcome to Discourse 3.0 everyone!
This UI is definitely going to take some getting used to, but there are some things I love on the desktop version of it. (A bit scared to open the mobile view).
Mobile view is fine for me (using the DiscourseHub iOS app). However it feels a little slower ![]()
And what does the new select thing do (highlighted)?
Also like the new popout menu
last artifact (from me)
When I mentioned it a few months ago, some members criticized it !
@admin, is this FAQ intentionally made to open in a new tab?
maybe it would be better if it behaved like all the other links from the menu (open in the same window).
btw. title is wrong here (because the FAQ leads to the DOCS section)
also
there is one problem
<del> now no longer marks only in red, but also crosses out the text test test
admin, can you somehow restore it to its old form (only red)?
I find it useful when I need to emphasize something to the users.
I already know what will be my routine every time I come to the forum ![]()
and that is to click this (to hide)
I would likely be part of that club. Likely because change tends to affect me negatively (I guess I get used to things and cannot detach myself from them easily), but also because I feel that it’s forcing mobile design on larger screens (I understand the sidebar for mobile, but I feel the dropdown was fine for PCs, or maybe I’m just weird again, I don’t know).
Update: As I’m used to clicking on the logo to go to the main page, doing that in the way I’m used to currently hits the menu button. Thanks, I hate it ![]()
In any case, it is what it is, and I’m sure the positives will outweigh any negatives. On the road to Discourse 4.0!
I don’t like changes in general either
but such visual changes bring one advantage, at least we are not bored and bring a little freshness.
The previous right menu was overcrowded with things in a small space and unreadable
some members didn’t even know it existed
or how to get to the “profile” section
now it’s done better
