Wait, why are you decoding a JSON object and then encoding it again? Additionally, json_encode does not take two parameters, it takes one. I think you’re confused with json_decode, which can take two parameters. And yes, there is a difference between json_decode($str) and json_decode($str, true).
This will turn $json into an array that we can access anytime. Let’s say we want to get the value of key_2 – we can achieve that by using $json_obj["key_2"], which will output value_2. If we want to access the obj1’s keys we can do that by using $json_obj["obj1"]["obj_key1"].
I find it so hard to believe that I signed up in 2018, and that my forum account is newer than @MAHOfficial’s, who I believed join from Byet. I thought I was gen2017 for some reason lol. I also find my first posts unlikely to have been my first posts…
Welcome to the MOFH community! Feel free to drop around their forum. We’ll try our best not to bite.
Come on, where’s the fun in that?
I hate this so much, yet it’s the one principle in programming that cannot be defeated. Maybe one day we’ll be able to surpass this limit
On an unrelated note, had a weird Google glitch that showed the normal results for my username as normal, while when putting “infinityfree” next to it I’d get the NSFW warning. I’m curious as to what content that would be
Xera is no longer maintained, MOFHY-R is the new one. But nobody knows if there are vulnerabilities or major bugs with it yet (It seems to have less features though).
Personally, I would start building your own system. If you want, I can let you into by BETA test for my software, and I will be happy to answer your questions! (PM me)
Or, use Xera as a starting base and built off of it (As long as you know Codinger)
Of course!
Xera’s setup instructions and docs are at its own forum, https://fourm.xera.eu.org/. They might be a bit confusing, so feel free to ask anything at either the community forum or even better, the unofficial Discord, and someone will direct you to the right place. Follow the instructions in the GitHub and try to experiment in a localhost environment to get to know it, or directly at your host, whichever you prefer.
As @Greenreader9 mentioned, Xera is no longer supported and the same author has released MOFH-R (not MOFHY, this is important, don’t download anything MOFHY unless you wish to get your data leaked).
It’s under development and the instructions are also on its own forum, https://nxvim.freeflarum.com/. I haven’t experimented much with it, unlike Xera.
*CodeIgniter, lol.
I’m in both the Byet and PFH communities… had no idea any of them was NSFW
Maybe not you specifically, but others on that dead discord server that is supposed to be active probably will be. Seems maybe I won’t have to give out as many Gift Cards as I originally planned!
When the article was written, both sites were just web frontends around Let’s Encrypt. Let’s Encrypt supports HTTP validation or DNS TXT validation, and none of those work with free hosting (without using additional tools, anyways).
Then, ZeroSSL became a Sectigo partner, which game them access to other verification methods, including CNAME, and they bought sslforfree.com so it’s just another domain that uses ZeroSSL’s systems.
So both providers (since they are the same) can be used now with CNAME verification, so the article is no longer relevant.
I can’t for the life of me imagine why you’d want to though. ZeroSSL limits you to three free certificates, which we don’t, and with our panel you can have us set up the CNAME records and SSL certificate automatically.
So in short: the article is no longer relevant, and it should be gone now.
