Thanks!
Pop-ups and those corner video ads are the ones I hate the most
For those who have Twitter acc
read deeper in the comments here
in short, NAFO did its part adequately :star_struck:
I like TinkerTechLab, the design is good, and I sometimes go on there when I have a problem.
Brave Browser? Might help you out a bit, it blocks a ton of ads.
I do use brave at home, and it works just as well as adblockers.
The issue is that with first party cookies, even if the ads are blocked, it can be made easier for Google to track you.
Does anyone know how to remove everything before the last occurrence of a string in a string PHP?
That was confusing, so below is example:
Input: this/i/is/i/a/i/string
I want to remove everything before the last occurrence of /i/ (Including the last /i/)
Output: string
Oh, And the number of /i/'s in the string varies, it will never be the same number (For example, both this/i/string/i/says and jim/i/says should return says)
Sorry if that was confusing, and thanks in advance!
use strrchr() available since v4.
substr(strrchr("h/j/i/s", "/i/"), 1); //returns: s
See: PHP: strrchr - Manual
btw i found that in less than 3 minutes with a google search.
You beat me to it! If only I had seen it earlier.
This does not work though:
echo substr(strrchr("h/j/i/p/s", "/i/"), 1);
It returns s, but should return p/s
OK, so strrchr() didn’t work (I’d never heard of it before), but this tried-and-true solution works:
$string="h/j/i/p/s";
$find='/i/';
echo substr($string, strrpos($string,$find)+strlen($find));
Yep, that worked, thanks!
@Greenreader9 I’m not sure if this was on purpose but I believe what you meant to put was “Flexible” not “Flexable”.
What are first party cookies as opposed to third party cookies?
I mean, yes, they are by the web owner but how does that allow ads?
Does the web owner sell the info?
Also, rock anyone?
First party cookies are cookies that load from your site, instead of from a third party site. In the past, Google would store a third-party cookie when you visit a website to help personalize your experience. Now, they will start storing that same cookie, but it will act like a cookie the website set, not a cookie that Google set. (Probably not the best way to explain it)
Good-by Google Webmaster Guidelines!
https://twitter.com/Marie_Haynes
prepare for topics about monstaFTP - certificate has expired
btw. @Deveroonie WB again :wink:
I found that out around one hour ago but I decided not to post that on this topic.
This will definitely bring a lot of topics
Feel free to post useful information if you come across it - so we can prepare.
It should be auto-renew…I hope we won’t have to wait long :upside_down_face:
And on weekends, ifastnet often does something on the servers
so some fireworks are possible on e.g. Sunday.
Aziz light ! -1
Aziz light ! - 2
Basically chrome will say that cookies set by google are actually set by the website? Or have the same effect and permissions?
Starting to miss the presence of admin…
