Lots of interesting things this past week.
Alafabet crashed a food delivery drone in Australia, taking out power to 3,000 people, and diamonds are being made out of plastic.
Oh yeah, Musk might buy Twitter, and he embarrened himself again:
Decided to string together a bunch (3) of high-powered speakers to my computer and max everything out (Yes, I dismissed volume warnings to do so). I think something wrong with my hearing now…
Anyone know of a good song idea for such a setup?
Will do in an hour or so!
EDIT:
Listened to it at normal volume, and everything but the lyrics sounds really familiar for some reason…
I chose one that is clear even under heavy load
but this one is just as cool to me
first boost to max
and everyone thinks that the initial bass kick used is the main one
and then when he suddenly starts getting fat ![]()
I repeat, immediately set it to max and wait for the surprise
but that’s more just for a short surprise, otherwise it’s boring
this would be the smartest thing to do
Will do boss. If you blow my eardrums out you are getting the medical bill ![]()
Yep, automatically got it ![]()
Oh…
Yes
It’s a little bit profane, but if you can handle it then ![]()
Otherwise,
That one slaps, too.
I can’t believe the year is about to end! It feels like yesterday that we were in quarantine.
Yeah, time goes by very fast.
Know anything about google updater?
And if you do, do you have any resources?
Because, uh…
The frick is happening here? lol
(The image is the network line in mbps)
Chrome as well as if you have any other product from Google such as Google Drive for desktop,
is placed in the OS startup service (several of them), and this is not only done by the installation, but by the program itself, whenever the exe is started, it is inserted into the services/tasks, so that it would check/have the latest updates.
You will often find it (several) in the task scheduler and in the service (sys apps)
I don’t know why it goes back and forth in your chart
I assume that for some things you should zoom in (probably not possible) so you might actually be able to see
instead of this this
…depending on which time range it displays (refresh/update).
but again there are some curves that are silly.
Where is that graph from?
It’s from Killer Intelligence center.
I thought it might have been overwriting the previous data hence why it goes back on itself or a small error because I can’t zoom in (in other words, the previous value gets overwritten by new data so that it appears to be curving back on itself or the decrease is so minimal or something that it’s hard to make out when viewing it from the viewpoint that I have so it appears to curve back on itself). The one example you have is easy to guess what happened, but look to the wanky curve next to it. Those are the ones that puzzle me (the “silly” ones).
Ye, IK that chrome will initiate the program to update (the updater service starts when I go to the check for updates section in setttings). I was just wondering why the scale was so fragmented. It probably downloads in small packets.
Would a “Support us with crypto” area get my site banned, there is a rule against crypto.
Don’t do it if you want to play safe
judging by the review on the store
it’s no wonder that the network graph is going crazy (or interferes with your connection in a way that actually destabilizes it)
Only five more days until I visited this forum for a year!
TBH, it works fine for me.
Aside from that, I really like how it allows you quite a bit of control over things. I’ve never really had control over network throttling before this, so…
Although I bet that there could be better software, I am sure.
Reading the reviews, it’s mainly about installing. It came pre-installed for me and it works fine. Sure, there are some things I wish I could do (like resetting changes instead of the throttling of one app instead of having to reset everything), but it works fine for me.
Trying to make my own dubstep after having extreme envy for those who could do it so well.
Wish me luck!
Oh and:
Another one ![]()
