What did you do to get tired? Can you please throw some light on us?
good thing is - youâre not retired
I could tell; their devtools is almost exactly the same!
Chrome can to some extent do that
Iâm having heavy headache -,-
Done!
These âquick searchâ tiles or whatever theyâre called are actually really helpful.
And I have set it up so I can type
@infinityfree
and then the query so I donât have to press the button.I am not from any country on the list .
Not if I consume the plant first.
Actually, they use more oxygen than they put out.
Yep. Here we are again.
Fairly active before when I had tests and other things to do.
Absolutely nothing here when I have nothing to do.
Maybe its a sign to actually do the thing Iâm procrastinating on.
Hmmm
Wait, you have a screen time timer?
Imagine not being the admin of your own computer
Btw they need strike-through to go over emojis
Today is 1 week before my first freenom domain expires. But I didnât see renew option. Is it visible 3 days before instead?
- Go here https://my.freenom.com/domains.php?a=renewals (sign in if necessary)
a. Or just click âServices > Renew Domainsâ - Click ârenew this domainâ
- Done.
- Check nameservers, etc to make sure everything is still in order.
It works, thanks
14 days before the expiration you can renew and they should send you an email as a reminder to do so
but whether you received an email from them or not
it is advisable to make yourself a reminder on your mobile phone or somewhere just in case.
