yes of course m yes i would love to inject a petabyte into my brain
Imagine a job description in the futureâŚ
âwe are looking for 100 people who will work as a file serverâ ![]()
you see, even in an star trek voyager
there is memory in some Bio-neural gel
lol
And Iâm a bit worried about our schoolâs use of a monitoring software!
GoGardian has removed the functionality to access cams. Also, just use tape!
(Note that the little light by the cam is hardwired into almost every laptop, so there is no way to activate the camera without the light going on.)
Yeah, IDK about hardwired, but if not then it is likely handled by system software, which probably (I donât doubt that the device manufacturers did this for a reason) isnât controllable by software.
Yea, but schools could use an older version of GG (although, I donât know for sure). As for the tape, yeah just take a piece of paper and put it over your camera ![]()
(The link is to Quora)
Admin said itâs a bad CloudFlare cache. Ctrl+Shift+R fixed the problem for me.
Happens occasionally, its a CF issue. Sometimes a 503 error happens as well.
I did CTRL + Shift + R it still didnât work.
Try a different browser or VPN
Just installed GIT and GitHub Desktop on my PC, Seams a bit complicated to add folders to one of my projects, but I did it. Anything noteworthy I should know (Yes, I ignored all documentation and user-onboarding like normal
soooooooo you are going to sit there forever without going home amirite
england
probably such a thing will not happen because everything stored inside would affect your mind
it is not easy to separate the brain from the mind (if is even possible)
Hey, I donât even know Github that well.
